A way to apply color to layers, in bulk.
Theoryshaw
Post by Theoryshaw » Fri Jan 26, 2024 8:31 pm
Let's say you have 100 layers all assigned to the color white. Is there script or UI approach that could apply random colors to these layers, in bulk?
Or a mapping interface where you could have a text file with something like the following
Layer Name X = Red
Layer Name Y = Green
Layer Name Z = Blue
...and run this in bulk?
Re: A way to apply color to layers, in bulk.
Post by CVH » Fri Jan 26, 2024 11:54 pm
Is there a (script or) UI approach that could apply random colors to these layers, in bulk?
Yes these things are perfectly possible with scripting.
I don't see the purpose of random colors but how distinct should they be? QCAD supports 24bit colors.
There are 18 predefined CAD colors.
For mapping you list primary colors and for this you need those 100+ layer names.
