Automatically close profiles
ryden
Post by ryden » Thu Dec 07, 2023 4:29 pm
Hello!
I have a problem where i need to remove all radii/Rounds on a lot of features in a sketch.
2023-12-07 16_24_00-105294 #01 L3 Shim layer.DXF _ - QCAD.png (13.35 KiB) Viewed 3285 times
I can use the selection filter to find all radii and remove them.
Now i have to use the trim2 tool to manually trim all lines to sharp edges.
Is there a way to automate this in any good way?
Thanks in advance!
/Johan
Re: Automatically close profiles
Post by Husky » Thu Dec 07, 2023 7:33 pm
after deleting the radii did you try to built a polyline with "Polyline from Selection"? Probably you have to adjust the tolerance in Preferences ...
There could be also the posibilitie to copy/paste the rectangle shape using stored points. For that all rectangle shapes have to be identical in size but without seeing any example dxf just a wild guess from me ... :wink:
