Adding to menus/toolbar within script
mechatronic
Post by mechatronic » Wed Nov 15, 2023 9:34 am
I've got a pre-processor for QCAD-CAM that I'm expanding, and need to add some menu/toolbar options. They're related to the specific post-processor, so only should be shown when it's selected and is being used.
I've found a programatic way of updating the CAM Configuration dialogue, but I have no idea about Qt, so unsure how I'd amend the toolbars/menus in the same way. I know I can create new menus etc using the folder structure (and have been playing with the samples), but I need everything to be contained within the pre-processor's .js file.
Re: Adding to menus/toolbar within script
Post by andrew » Wed Nov 15, 2023 11:35 am
I wouldn't recommend adding menus or toolbars for a particular post processor (although it's likely possible).
If possible, add configuration options to the CAM Configuration dialog.
Perhaps, you can elaborate on the tools you want to add, so I can be more helpful.
