ExSetColor.js script issue
WildWolfCJ
Post by WildWolfCJ » Tue Nov 14, 2023 3:57 am
QCAD 3.28.2 pro windows10
I'm learning to debug the ExSetColor.js script using .\qcadcmd.com -enable-script-debugger -autostart .\scripts\Misc\Examples\CommandLineExamples\ExSetColor\ExSetColor.js D:\software\QCAD3.28License-20231026\qcad -3.28.2-pro-win64-2\qcad-3.28.2-pro-win64\scripts\Misc\Examples\CommandLineExamples\ExSetColor\test.dxf D:\test1.dxf prompt Warning: RScriptHandlerEcma::eval: script engine exception: "ReferenceError: Can't find variable: getOpt"
I searched the API documentation to no avail and couldn't find the getOpt definition.
Re: ExSetColor.js script issue
Post by CVH » Tue Nov 14, 2023 7:03 am
I searched the API documentation to no avail and couldn't find the getOpt() definition.
You are correct, I think this is deprecated.
(Commented out in RScriptHandlerEcma.srcml)
Other (active) Command Line tools include scripts/Tools/arguments.js to handle command line arguments.
Over to Andrew.
Post by CVH » Mon Nov 27, 2023 11:59 am
On Nov 19, 2023 Andrew ported ExSetColor.js to use arguments.js
This fix is not immediate and is most likely included in upcoming releases.
For evaluating this example script meanwhile you may want to source it directly from GitHub:
https://github.com/qcad/qcad/blob/maste ... etColor.js
