How to intersect entities to create new geometry
arun
Post by arun » Wed Sep 27, 2023 11:50 am
I have the following entities in my dwg
  • a slab layer containing a polyline entity
  • a beam layer containing multiple polyline entities
I know how to identify the beam entities that are contained inside the slab polyline.
How do I divide the big slab into multiple smaller slabs?
Or how do I generate new polylines that share the edge of the beam entities (here the edges will be between intersections of beams)
Attaching along screenshots and dxf file
Yellow indicates Slab & Red indicates Beam
Thanks,
Arun
Version: QCAD Professional 3.28.2 on MX Linux
Slab Test.dxf
(103.97 KiB) Downloaded 193 times
Slab Test.png (20.75 KiB) Viewed 7559 times
Re: How to intersect entities to create new geometry
Post by CVH » Wed Sep 27, 2023 5:20 pm
QCAD has no concept of enclosed areas.
You could play with a solid hatch of a multiple selection.
If the hatching works out then you can select it and explode it to the boundary shapes.
These shapes can then be merged into polylines.
arun
Post by arun » Thu Sep 28, 2023 1:41 am
Thanks CVH. Will check this out.
Post by CVH » Thu Sep 28, 2023 4:57 am
made a trial case with your Slab Test.dxf and it doesn't work out. :(
You get the initial 6 polylines back exploded to 24 lines.
The solid hatch looks perfect but the beam shapes are not merged for that.
Like I said, QCAD can not merge, subtract, xor ... areas, everthing is basically line art.
look here for how I merged 13242 filled areas of various entity types into 384+17 closed contours.
https://www.qcad.org/rsforum/viewtopic.php?f=32&t=10305
The example was way more complex than your example where it is the matter of drawing 4 new rectangles. :wink:
You need to write a really clever script to perform this kind of operations. :roll:
