Interactive Scripting to Interactive COGO [SOLVED]
Joseph1916
Post by Joseph1916 » Mon Jul 31, 2023 8:24 pm
I am revisiting this topic, it is a central issue.
Script ExMyMinimal.js and ExMyMinimal.xml simply seems to wait for a "grid" input point.......
Can anyone spot an issue why the problems?
Joseph1916
Re: Interactive Scripting
Post by Joseph1916 » Mon Jul 31, 2023 8:29 pm
Operating System: Linux Ubuntu 22.04
QCAD Version: 3.28.1
indentation appears in text file ExMyMinimal.js and ExMyMinimal.iu
After POST my indentation is remover. How come?
Thanks.
Joseph1916
Re: Interactive Scripting to Interactive COGO
Post by CVH » Tue Aug 01, 2023 5:33 am
Hardly. :shock: :!:
Remarked in several of your latest post is the use of some kind of HTML type tags:
e.g:
</e></QUOTE>
came back with a Parse Error. <br/>
<br/>
While the js file: <br/>
Why not using plain text?
While the js file:
You also quoted the XML and the JS code what make it even harder to read.
It is common to use a code panel for such things ... Select the code portion in your topic and use the '</>' button.
The functional UI I can retrieve is:
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
<class>ExMyMinimal</class>
<widget class="QWidget" name="ExMyMinimal">
<layout class="QHBoxLayout">
<item>
<widget class="QLabel" name="RadiusLabel">
<property name="text">
<string>&amp;Radius:</string>
</property>
<property name="buddy">
<cstring>Radius</cstring>
</property>
</widget>
</item>
<item>
<widget class="RMathLineEdit" name="Radius">
<string notr="true">1</string>
</property>
</widget>
</item>
</layout>
</widget>
<customwidgets>
<customwidget>
<class>RMathLineEdit</class>
<extends>QLineEdit</extends>
<header>RMathLineEdit.h</header>
</customwidget>
</customwidgets>
<resources/>
<connections/>
</ui>
Without the proper indentations but they don't really matter. :wink:
It looks like:
The naming of this plain text file should be: ExMyMinimal.ui
And now the JS script .... :roll: ... With indentations, it is common to use 4 spaces for a tab in QCAD.
include("scripts/EAction.js");
function ExMyMinimal(guiAction) {
    EAction.call(this, guiAction);
    this.pos = undefined;
    this.radius = undefined;
    this.setUiOptions("ExMyMinimal.ui");
ExMyMinimal.prototype = new EAction();
ExMyMinimal.prototype.beginEvent = function() {
    EAction.prototype.beginEvent.call(this);
    di.setClickMode(RAction.PickCoordinate);
ExMyMinimal.prototype.pickCoordinate = function(event, preview) {
    this.pos = event.getModelPosition();
    if (preview) {
        this.updatePreview();
    else {
        this.applyOperation();
ExMyMinimal.prototype.getOperation = function(preview) {
    if (isNull(this.pos) || isNull(this.radius)) {
        return undefined;
    var doc = this.getDocument();
    var op = new RAddObjectOperation();
    var circle = new RCircle(this.pos, this.radius);
    op.addObject(shapeToEntity(doc, circle));
    return op;
ExMyMinimal.prototype.slotRadiusChanged = function(v) {
    this.radius = v;
ExMyMinimal.init = function(basePath) {
    var action = new RGuiAction(qsTr("&Minimal Example"), RMainWindowQt.getMainWindow());
    action.setScriptFile(basePath + "/ExMyMinimal.js");
    action.setGroupSortOrder(100000);
    action.setSortOrder(0);
    action.setWidgetNames(["ExamplesMenu"]);
The naming of this plain text file should be: ExMyMinimal.js
Can't detect any coding error with this ... It draws a circle with the radius from the UI at the indicated position ...
... Probably you tried to implement this with all the unrelated/faulty tags in place.
Please use a plain text editor.
On windows I can advice Notepad++ using the formatting language 'JavaScript' and using the Unix EOL.
I am sure there will be Linux alternatives.
And please use plain text to enter topics. :wink:
Joseph1916
Post by Joseph1916 » Tue Aug 01, 2023 4:18 pm
Hello CVH,
Lots to consume with your posting..... How do i ensure my Posts are in plain Text? Is that an option? Anyway, now using Genome Text Editor, hopefully in will resolve some of the problems.
I have limited programming background and especially with MS Windows and the Internet(i.e. JavaScript, HTML, etc.)
I will attempt to solve my problems one by one. The code is still not executing correctly. RESOLVED
CODE is now executing.
Thanks for all your help !!
Joseph1916
Joseph1916
Post by Joseph1916 » Tue Aug 01, 2023 4:43 pm
I have solved some problems :-) However, code executing properly :-)
Joseph1916
Joseph1916
Post by Joseph1916 » Tue Aug 01, 2023 4:45 pm
I have the code working !!
Post by CVH » Tue Aug 01, 2023 4:53 pm
I enter ... type ... this in the reply box and it comes out as plain text, right?
The same is true when you do that in the text box for new topics.
ExMyMinimal.ui and ExMyMinimal.js should both be located in a folder called ExMyMinimal somewhere under the script folder.
For example: ... QCAD/scripts/Misc/Examples/ExMyMinimal where the 3 dots represent your QCAD installation path.
Post by CVH » Tue Aug 01, 2023 5:07 pm
NO I have not !!
What have you not ...?
So far the second version of your code is exactly the same as the previous and as mine except indentations, except as code in a code panel.
One edit own posts, see the button with the pencil in it.
Joseph1916
Post by Joseph1916 » Wed Aug 02, 2023 6:17 pm
CVH ;
Sorry for the delay with this reply...... What I was referring to was earlier Post. I was basically chatting to myself. Disregard that statement.
I do not see how you get the "white code box" to reflect Code? Knowing how to do that could help me communicate !!
Regarding my current Script, let me do additional investigations, as to the source for the failing Script. We know it is on my side !!
Thanks for your support !
Joseph1916
Post by CVH » Wed Aug 02, 2023 6:53 pm
When you are writing a topic you can copy/paste some code text to include it.
Then select the pasted code lines.
At the top of the text box there is a ribbon with buttons.
With the code lines selected hit the '</>' button.
Similar for setting text bold, italic, underlined ...
This is code
Will be displayed on Preview or Submit as:
This is code
In text form a code box starts with 'code' between squared brackets and ends at '/code' between squared brackets.
It speaks for itself that I couldn't include these brackets in the above sentence. :wink:
Or you could hit the code button an then insert the lines of code between the two formatting tags.
Joseph1916
Post by Joseph1916 » Wed Aug 02, 2023 6:56 pm
My mistake. The Dialog was at the top..... Did not expect that....... SUCCESS.... Sorry I took such time..... We can all move on...
Joseph1916
Post by CVH » Wed Aug 02, 2023 6:59 pm
Yes, please, and maybe you want to declutter this topic by editing your own posts. :wink:
