replace a block reference with another block
arun
Post by arun » Mon Jul 24, 2023 9:47 am
How do I replace a block reference with another block reference in qcad script.
I am using qcad 3.28.1 on linux.
Thanks,
Arun
Re: replace a block reference with another block
Post by CVH » Mon Jul 24, 2023 10:57 pm
Query the block reference entity by id:
var doc = this.getDocument();
var blockref = doc.queryEntity(entityId);
Query the block definition by the intended block name:
var block = doc.queryBlockDirect("MyNewBlock");
(Query Direct, no modification required)
Set the referenced block id of your block:
blockref.setReferencedBlockId(block.getId());
Cast the modified block reference back to the drawing:
var op = new RAddObjectOperation(blockref, false, true);
(NOTuseCurrentAttributes, undoAble)
di.applyOperation(op);
Another option is to use an RModifyObjectOperation() instead:
var op = new RModifyObjectOperation(blockref);
It is best that you verify that a block reference entity and a block is returned instead of nothing.
And it might be required to clone the reference first.
arun
Post by arun » Tue Jul 25, 2023 5:57 am
Thanks CVH :) . Will check this out.
