2 tools I need to work in architecture
ggsalas
Post by ggsalas » Fri Jan 30, 2009 4:56 am
Hello, I want to show the 2 tools I need to work in architecture.
1 - Use blocks for each floor, cut and view. Able to insert in different scales.
http://picasaweb.google.es/lh/photo/BgE ... bedwebsite
2 - Use accumulated dimension
http://picasaweb.google.es/lh/photo/JFF ... bedwebsite
Sincerely, thank you.
ggsalas
More about the 2 tools they need
Post by ggsalas » Thu Feb 05, 2009 2:41 pm
http://www.ribbonsoft.com/rsforum/viewt ... highlight=
http://www.ribbonsoft.com/rsforum/viewt ... =1936#1936
Regulations:
(IRAM is for Argentina. Sure that ISO is the same in this aspect)
- (IRAM) Manual of rules for technical drawing. (https://www.u-cursos.cl/fau/2008/2/DIP- ... bjeto/4313)
http://picasaweb.google.es/lh/photo/Dgl ... directlink
- (IRAM) Manual of standards for technical drawing, volume 2. Page 45.
http://picasaweb.google.es/lh/photo/hGu ... directlink
- Example drawing:
http://picasaweb.google.es/lh/photo/geV ... directlink
Greetings
usermarius
THERE IS ONE MORE IMPORTANT THEN MENTIONED THING
Post by usermarius » Wed Mar 24, 2010 6:50 pm
THERE IS ONE MORE IMPORTANT THEN MENTIONED THING-
according ISO in architecture arrows should look like 45 degree line like
it's the only reason why I am not using like the main program QCAD. And another reason I have no time to compile open source QCAD to use that looking arrows. So I have to stay on windows running another free software.
anyway you are not using that kind of arrows
I looking forward for changes in community edition too :)
Post by andrew » Wed Mar 24, 2010 7:11 pm
usermarius: Edit - Current Drawing Preferences - Dimensions - Style - Architectural Tick
Return to “QCAD 2.1/2.2 Suggestions and Feedback”
