Guidance needed in installing vec2web
If you are having problems with vec2web, post here. Please report bugs here.
Locked
ringer
Post by ringer » Sat Oct 30, 2010 5:46 pm
I am running on Ubuntu 10.4
Have downloaded the file vec2web-2.0.4.7-1.src.tar.gz
and extracted it using...
gzip -dc vec2web-2.0.4.7-1.src.tar.gz | tar xvf -
so I now have a folder vec2web-2.0.4.7-1.src
I have run ~/vec2web-2.0.4.7-1.src/build_vec2web.sh
it is complaining 'QTDIR not set. Aborting..'
Now the instructions on your download page say...
Includes script to build vec2web from scratch. Requirements: the Qt developer edition, version 3.3.x.
but there is no instruction on where I can get 'QT developer edition, version 3.3.x' which I presume will create the QTDIR environment variable when it is installed.
I have tried 'sudo apt-get install qt3-apps-dev' in the hope this was the correct package but it seems not as I still do not have a $QTDIR environment variable
can you please tell me what to download e.g sudo apt-get install qt#####
Locked
Return to “vec2web Troubleshooting and Problems”
