vec2web & invisible attributes
Use this forum to ask questions about how to do things in vec2web.
askrius
Post by askrius » Tue Apr 28, 2009 4:55 pm
I have blocks with invisible attributes. when I use vec2web to convert my DXF files (generated w/Autodesk authorized software) to PNG if works fine...but it also shows all invisible text attributes!
Any ideas?
Post by andrew » Thu Apr 30, 2009 8:57 am
Attribute entities are not supported by vec2web / dxflib at this point and are imported as text entities.
askrius
Post by askrius » Thu Apr 30, 2009 5:53 pm
[quote="andrew"]Attribute entities are not supported by vec2web / dxflib at this point and are imported as text entities.[/quote]
Ah, thanks.
Any plans to add support?
Return to “vec2web 'How Do I' Questions”
