dxflib testing
If you are having problems with dxflib, post here. Please report bugs here.
rol51dd
dxflib testing
Post by rol51dd » Thu Nov 12, 2015 8:08 pm
Hello, For testing dxflib I have download the actual dxflib-3.7.5-src paket.
When ich use Qt Creator (3.0.1) for compiling (test.pro), then doesn't exist in the paket the named entry "tableLineTypes" and "writeLintType". In the classes of paket I can't find this?
Is this an error in the test.cpp file or what is missing?
Roland
Re: dxflib testing
Post by andrew » Fri Nov 13, 2015 9:13 am
You can get the latest files from our git repository at:
https://github.com/qcad/qcad/tree/maste ... rty/dxflib
I will also update the dxflib packages shortly.
Re: dxflib testing
Post by andrew » Mon Nov 16, 2015 10:11 pm
Updated dxflib packages are now available from:
http://www.qcad.org/en/dxflib-downloads
Return to “dxflib Troubleshooting and Problems”
