I need someone to answere me this questions.
Is dxflib still in develop?
when was the first dxflib version released?
why was dxflib created? was a colateral project born from QCAD?
Some questions about dxflib.
- Junior Member
Re: Some questions about dxflib.
Yes, you can get the latest version as part of QCAD through github:wolfhergang wrote:Is dxflib still in develop?
https://github.com/qcad/qcad/tree/maste ... rty/dxflib
1999 as part of QCAD 1.0.wolfhergang wrote:when was the first dxflib version released?
To read / write DXF files with QCAD.wolfhergang wrote:why was dxflib created?
Yes, dxflib is primarily the library used by QCAD to read / write the DXF format but is designed to be used independently of QCAD in other projects as well (no dependencies on Qt or QCAD libraries).wolfhergang wrote:was a colateral project born from QCAD?
