Some questions about dxflib.
Use this forum to ask questions about how to do things in dxflib.
wolfhergang
Post by wolfhergang » Fri Oct 25, 2013 8:42 pm
I need someone to answere me this questions.
Is dxflib still in develop?
when was the first dxflib version released?
why was dxflib created? was a colateral project born from QCAD?
Re: Some questions about dxflib.
Post by andrew » Fri Oct 25, 2013 10:00 pm
wolfhergang wrote:Is dxflib still in develop?
Yes, you can get the latest version as part of QCAD through github:
https://github.com/qcad/qcad/tree/maste ... rty/dxflib
wolfhergang wrote:when was the first dxflib version released?
1999 as part of QCAD 1.0.
wolfhergang wrote:why was dxflib created?
To read / write DXF files with QCAD.
wolfhergang wrote:was a colateral project born from QCAD?
Yes, dxflib is primarily the library used by QCAD to read / write the DXF format but is designed to be used independently of QCAD in other projects as well (no dependencies on Qt or QCAD libraries).
Return to “dxflib 'How Do I' Questions”
