Laser power control postprocessor
Alan F
Post by Alan F » Sun May 01, 2022 4:03 am
I have downloaded the QCAD/CAM trial and generated some gcode for the various laser cutters, none have allowed me to input the power required.
I am using a Cohesion 3D control board on a co2 laser, using Linux 64bit QCAD Version 3.27.3. on LinuxMint 20
The laser power setting required is from 0 to 1, example S0.5 for 50% power and S1 for 100% power.
Is it possible to modify a post processor to allow a spindle input in a range of 0 to 1?, currently 0.5 is outputted as 0.
Here is a sample line of gcode that I generate in Cut2d.
G1 X1.0000 Y1.0000 S0.5 F10.0
I have looked through the post processor and gcodebase java scripts and was not able to find any clues.
Can someone post a sample code that will generate the 0 to 1 spindle range and tell me which script needs to be copied and modified?
Thanks,
Alan
Re: Laser power control postprocessor
Post by Husky » Sun May 01, 2022 8:31 pm
Not my wheelhouse but could this do the trick ...?
There is a Post Processor tutorial out there - maybe it can help to find some clues ... :wink:
https://qcad.org/en/qcad-cam-postprocessor
Alan F
Post by Alan F » Sun May 01, 2022 9:25 pm
That almost does it. It would work fine if I'm only doing engraving or cutting but can't do both as they require different laser powers.
I was hoping to set up a couple of tools with the S value set for engraving and cutting and the post processor would pull from the tool data.
I have been using Cut2D to generate the gcode and there I would use a value of 0 to 100 because it would not let me use 0 to 1.
In the post processor that I modified I was able to use a math operation to divide the S value by 100 to get the 0 to 1 range.
Have not seen if this is possible in my search for QCad.
Thanks for the reply, for many tasks this is a good solution if a project only needs one S value.
Enjoy!
Post by Husky » Sun May 01, 2022 10:04 pm
Just for clarification: You need different Laser powers in the same drawing / g-code?
Alan F
Post by Alan F » Sun May 01, 2022 10:38 pm
Yes I need different laser powers in the same drawing and gcode so I can do engraving and cutting in one operation on the laser.
Post by andrew » Mon May 02, 2022 7:29 am
I've attached a post processor called LaserCohesionMM.js ("Laser Cohesion [mm]") for your reference. It produces spindle speed (= power) values with two decimals.
Note the references to spindleSpeed in the post processor which define it as having two decimal places and in initToolpath as being of floating type.
I don't know the codes required to switch on / off the laser, so there might still be adjustments needed.
LaserCohesionMM.js
(1.6 KiB) Downloaded 329 times
Alan F
Post by Alan F » Mon May 02, 2022 1:44 pm
Thanks Andrew!
I will give this a try tonight.
Just providing the spindle speed with a value turns the laser on.
Have a great day.
