Hello.
I changed a scale parameter in the user interface (I put 0.75) and now qcad is useless and I can't restore it: even if I access preferences it doesn't make me change anything . I tried reinstalling it but it keeps the previous settings. is there a way to restore it to factory conditions? help me please!!
ubuntu 21.10
qcad-3.27.1-trial-linux-qt5.14-x86_64.run
modified user interface
- Newbie Member
- qcad schermata.png (46.18 KiB) Viewed 9907 times
Re: modified user interface
I'm answering from memory because my new laptop is running Windows 11 (I was on Xubuntu Linux before), but... I think the QCAD config file is in ~/.config/QCAD. You can rename it (or the entire QCAD directory) and QCAD should return to defaults, then you can go from there.
Len
QCAD Pro
QCAD Pro
- Newbie Member
Perfect!! thanyou!!!
