QCAD keyboard buttons - command line
- Newbie Member
Good evening everyone,
I'm Italian.
I have a problem with QCAD: when I enter the commands in the appropriate line the unassigned keys, especially the special ones.
I ask if anyone has ever had a similarity problem and if they have solved it.
I specify that the language settings are correct and I have this problem only with QCAD.
Thank you
I'm Italian.
Thank you
Re: QCAD keyboard buttons - command line
Thanks for your post.
Please always indicate your operating system and QCAD version. Please read also the forum rules at the top (red).
- Newbie Member
I have ubuntu 21.10,
In the command line I pressed "@" and the screen displays ";"
thank you
thank you
- screenshot command line
- qcad screeshot.png (116.9 KiB) Viewed 12474 times
You very likely need to install a different package:
QCAD Professional 3.27.1 for Linux Qt 5.14 64bit (Installer)
File: qcad-3.27.1-pro-linux-qt5.14-x86_64.run
- Newbie Member
i installed the latest version, but the problem remained,
other ideas
other ideas
Please indicate what exact package you have downloaded (exact file name). Thanks.
- Newbie Member
I have installed this version: qcad-3.27.1-trial-linux-x86_64.run
This version is bad?
I've moved your question to the pre-sales forum as you are not using the full version of QCAD Professional.
On the download page, scroll down to "All Downloads", then
Linux 64bit Qt 5.14 (Wayland support) Installer
- Newbie Member
Thankyou verymuch!!
but i have another problem now.... i open a new topic...
