[solved] Inserted images - ability to adjust (QCAD Pro)
bmac_2780
Post by bmac_2780 » Sun Aug 29, 2021 11:46 pm
I note images can be inserted and can be moved to front or back. Is it possible to adjust brightness and contrast of an inserted image and are such settings maintained for printing? Thank you.
Re: Inserted images - ability to adjust (QCAD Pro)
Post by Husky » Mon Aug 30, 2021 1:03 am
No - brightness and contrast is not supported by QCAD. Position, size, rotation, flip, bring to front / back, more or less visibility (fade) is pretty much what you can do with a bitmap. At the end of the day QCAD is a CAD application.
bmac_2780
Post by bmac_2780 » Mon Aug 30, 2021 1:12 am
Thanks Husky,
Fade is the main feature I need. Thanks for the info.
