Solved Library Browser
Henry21
Post by Henry21 » Thu Jul 29, 2021 8:34 pm
I am trying the trial version of QCAD, Looks good so far, Two questions: 1) the Library, does that come with the professional version if not, where? 2) Can printing be taken to a print store to be printed on D size paper?
Thanks, Henry :)
Re: Library Browser
Post by Husky » Thu Jul 29, 2021 9:04 pm
Hi Henry,
Yes, the Professional version comes with a "minimal " Library selection. Why minimal? Every user needs different Libray items - it makes no sense to clutter your Hard-drive with thousand of items which properly you never use. You can customize the library to your needs with additional items offered for free directly from the QCAD website https://www.qcad.org/en/qcad-add-ons or search the internet for additional items. This is also mostly offered for free ...
Yes - most print stores are able to do that! QCAD will use standard file types like dxf, dwg, svg pdf etc. If your print store has printer which cover the D size every thing should work flawless. To be sure - ask your print store if they support those file types.
BTW: I know a QCAD customer who prints his QCAD files without any problems on a 1,5 meter by 6 meter printer ... :shock:
