Nesting with cloud version and/or command line
chrispedersen
Post by chrispedersen » Mon May 24, 2021 3:45 pm
First: Thanks to Husky for a fast, exactly what I needed answer to my previous question. I'd like to suggest you add his post to the official tutorial.
And I want to say thank you for Andrew - because I gather you've written this? Which is amazing.
Can nesting be accomplished in the webserver version or in the regular Pro/CAM version via commandline or script?
The nesting is brilliant, but I'd hope to not use the mouse and command line at all.
Something like "nest sheet1.dwg, 8, part1.dwg, 3, part2.dwg, 4 part3.dwg,4" >> Sheet1.dwg, sheet2.dwg, sheet3.dwg
Re: Nesting with cloud version and/or command line
Post by andrew » Mon May 31, 2021 7:56 am
QCAD/CAM 3.26.3 comes with dwgnest:
https://qcad.org/en/products/qcad-comma ... (QCAD/CAM)
chrispedersen
Post by chrispedersen » Mon Jun 07, 2021 5:03 pm
Brilliant. I'll test it out today.
Funny thing was I looked over the list of commandline tools and missed it. One more question. I"ll make a new topic....
