Is there a title block template?
Damjo
Post by Damjo » Thu Jan 07, 2021 7:57 am
Hello.
Maybe a silly question but thought I'd ask.
Is there a setting or template in QCAD to add a title block or do we need to construct it ourselves?
Thanks in advance.
Re: Is there a title block template?
Post by CVH » Thu Jan 07, 2021 9:40 am
Post deprecated
Post by Husky » Thu Jan 07, 2021 9:51 am
QCAD comes already with a bunch of title block templates. You can use them as is or change them to suit your needs.
You will find them in QCAD below Menu / File / New from Template ...
Additional you will find a ton more title block templates within our forum below : "Creating DXF/DWG items".
viewforum.php?f=51
Damjo
Post by Damjo » Thu Jan 07, 2021 12:26 pm
Ah thank you both.
Can I also get a quick sanity check? It's been a while since I've used CAD software :?
I need to work at a 1:100 scale for some floorplans (1 centimetre = 1 metre). What settings am I supposed to change in QCAD to reflect this? Is there a way I can have units of measurement displayed alongside units when I'm measuring?
Post by Husky » Thu Jan 07, 2021 10:18 pm
To keep the forum overseeable and easily searchable ...
For every unrelated additional question please open a new topic and we are happy to help you. :wink:
Damjo
Post by Damjo » Fri Jan 08, 2021 3:17 am
Apologies! Let me sort that out right now.
Malachi II
Post by Malachi II » Sat Mar 13, 2021 4:53 pm
There does not seem to be a "New from Template" option on my Mac version.
I am using QCAD 3.26.1.0 for macos 10.13.6.
By right clicking the QCAD application I can see that the templates are there.
Post by Husky » Sat Mar 13, 2021 7:01 pm
The QCAD Community Edition comes without a "New from Template" option ... :wink:
