I'm trying QCad 3.24.3-64 but I have some problems to select blocks.
When I'm trying to edit an old block I cannot select the objects inside. If I draw a line in the old block it can be select.
Same in the main draw: some blocks is possible to select some other no.
I did some screenshots. Could you help me to understand what's wrong?
Thansk
Marco
[solved] Problems with blocks
- Select is working and blocks are selected
- 11.jpg (76.87 KiB) Viewed 7420 times
- Select 2 blocks on main draw
- 10.jpg (99.01 KiB) Viewed 7420 times
- Only new lines are selected
- 09.jpg (87.82 KiB) Viewed 7420 times
- Trying to select the 2 blocks with some new lines
- 08.jpg (97.96 KiB) Viewed 7420 times
- Trying to select 2 blocks in main draw but nothing happen
- 06.jpg (91.04 KiB) Viewed 7420 times
- 05.jpg (98.36 KiB) Viewed 7420 times
- Trying to select
- 04.jpg (121.27 KiB) Viewed 7420 times
- Draw new lines in old block
- 03.jpg (99.24 KiB) Viewed 7420 times
- Trying to select old block but nothing happen
- 02.jpg (108.84 KiB) Viewed 7420 times
- Old block
- 01.jpg (106.57 KiB) Viewed 7420 times
Re: Problems with blocks
thanks for the screenshots but in this case we need to see the dxf to see what is going on. Please attach the dxf to this topic for further investigation. Thanks.
Re: Problems with blocks [Solved]
Problem solved: I didn't notice that I blocked a level by mistake.
Thanks for fast reply anyway!
Marco
Marco
- --.jpg (16.45 KiB) Viewed 7362 times
