I'm making a CNC machine for plasma cutting and engraving.
Can I with the qcad/cam program dwg/dxf files import with bending lines?
Bending line is an other type line (- - - ). Can this program handel it to switch tools in the same program (offset Y axis)?
Switch to tools in the same program
Re: Switch to tools in the same program
Tool changes are possible, yes. Simply add the tools and the toolpaths for each tool and QCAD/CAM will switch tools between toolpaths. See also:
https://qcad.org/en/tutorial-qcad-cam
Can you elaborate on this or attach an example file or screenshot? Different line patterns are supported if that's your question.Can I with the qcad/cam program dwg/dxf files import with bending lines?
Ok thanks
see the pic to the different line types
- Naamloos.jpg (56.21 KiB) Viewed 6425 times
QCAD/CAM should be able to load / display that file. To ignore the bending lines, simply don't create a toolpath for them.
To evaluate all possibility's in QCAD/CAM it makes sense to explore the free of charge trial version.
https://www.qcad.org/en/qcad-downloads-trial
Better safe than sorry!
