Plotter drivers
mike001
Plotter drivers
Post by mike001 » Mon Apr 20, 2020 1:12 pm
Can I use the Roland DXY1200 plotter with Qcad? I understand that the command set is the same as the HP7550.
Re: Plotter drivers
Post by andrew » Mon Apr 20, 2020 1:17 pm
QCAD prints through the regular printer drivers installed on the operation system level. It doesn't have any other printing / plotting capability built in.
I'd recommend to try to plot using the free trial version:
https://qcad.org/en/download
