I am thinking of purchasing QCad and have the trial version at the moment.
I am unable to import older files originally generated by Autocad LT.
The layer information is there but there are no drawings viewable.
Are you able to help me please?
[solved] Unable to view Autocad Lt dwg files
Re: Unable to view Autocad Lt dwg files
Hi peterfz30 - welcome to the QCAD forum.
You'll find them in the Block List, then chose a Layout Block, then click the Edit icon ...
If that doesn't solves the issue please attache one of those drawings to this topic. Thanks.
Check the Layout Blocks (Paper_Space) - maybe the drawings are hidden there ...
Thank you, that helped.
