Trial ??
Re: Trial ??
Post by andrew » Thu Apr 09, 2020 8:02 am
Printing the current view is not meant for very precise alignment. The view proportions in all likelihood don't match the paper proportions, so QCAD has to compromise. For precise alignment on paper, you really need to work with the print preview or with print layouts:
https://qcad.org/en/tutorial-working-wi ... -viewports
Re: Trial ??
Post by Husky » Thu Apr 09, 2020 9:36 am
Ludek wrote:
Thu Apr 09, 2020 7:47 am
I am not able to print the drawing (make pdf), where the corner marks are just in the corner of the paper with no margin from each side in the QCAD. If you are please give me a hint how to do that.
A few things what I noticed ...
The drawing in Model_Space has metric proportions and I think you used for printing an imperial paper size (ANSI A Letter) instead of ISO A4. That is close .... but not close enough. :wink:
The pdf is metric.
Re: Trial ??
Post by Husky » Thu Apr 09, 2020 9:52 am
Forgot ... :oops:
Scale 1:7.5 looks more appropriate than 1:5
