Trial ??
berg
Trial ??
Post by berg » Wed Apr 08, 2020 1:13 pm
QCAD is a free, open source application for computer aided drafting (CAD) in two dimensions (2D)
I downloaded QCAD Trial for Windows 64bit - is it wrong file?
Anyway - €33 is not much for this if it will work.
But how can you call it "trial" if I can't try printing.
Just pay to realize that it does not work?
I do not understand this limitation.
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 1:16 pm
The trial can print, just like the full version of QCAD Professional, but with a watermark.
Help with printing:
https://qcad.org/en/tutorial-printing
If you're looking for the free version, that's not the same as the QCAD Professional trial version, that would be the QCAD Community Edition (i.e. remove the QCAD Professional trial plugins). The free version also prints of course.
berg
Re: Trial ??
Post by berg » Wed Apr 08, 2020 1:40 pm
Already read help before - no success. "Print current view" prints only some elements and not only from current view.
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 1:43 pm
If elements are not printed, check the lineweight. Lineweights of 0.00mm are not visible on some printers. Also try to export to PDF instead.
berg
Re: Trial ??
Post by berg » Wed Apr 08, 2020 2:11 pm
I'll give up. No matter what lineweight i set, no result.
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 2:15 pm
Did you try the PDF export? Can you attach the drawing file?
berg
Re: Trial ??
Post by berg » Wed Apr 08, 2020 2:21 pm
All I get is "paper" with light gray text "Printed with a trial version ....."
Can't see where I could eport to pdf the current view.
Printing to "Microsoft print to pdf" - as above.
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 2:23 pm
Again, can you attach the drawing file?
berg
Re: Trial ??
Post by berg » Wed Apr 08, 2020 2:26 pm
File is uploaded to Onedrive
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 2:39 pm
1. Load the file.
2. Select and delete a small entity / artefact all the way at the top right corner (red dot):
Screenshot 2020-04-08 at 15.31.51.png (411.97 KiB) Viewed 10711 times
3. View > Zoom > Auto Zoom (optional):
Screenshot 2020-04-08 at 15.31.56.png (539.64 KiB) Viewed 10711 times
4. File > Print Preview:
Screenshot 2020-04-08 at 15.32.03.png (527.18 KiB) Viewed 10711 times
5. Switch to landscape and auto fit on paper:
Screenshot 2020-04-08 at 15.32.11.png (529.94 KiB) Viewed 10711 times
6. File > Print or File > PDF Export
Again, most lines are 0.00mm wide, which might or might not be visible on your printer or in your PDF viewer. PDF attached for your reference.
2017.11.27.PLAAN_KÜTE.pdf
(383.48 KiB) Downloaded 443 times
berg
Re: Trial ??
Post by berg » Wed Apr 08, 2020 2:56 pm
I had a task from boss to find him a software, witch allows him to print selections from drawings and maybe in some cases to draw there additional circles and rectangles to determine equipment placement for installers.
In this case even print is too complicated, he'll never use it.
Over & out
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 3:19 pm
No problem. Good luck.
Ludek
Re: Trial ??
Post by Ludek » Wed Apr 08, 2020 4:16 pm
Hello I am struggling with printing as well. I miss a simple function: Print the selected window, like others have – see the figure. (Example is the DWG True View). Do I miss something?
Re: Trial ??
Post by andrew » Wed Apr 08, 2020 4:59 pm
That would be File > Print Current View.
Ludek
Re: Trial ??
Post by Ludek » Thu Apr 09, 2020 7:47 am
Hello, this works only partially. I have attached the dwg file and the pdf file I have created from the DWG True View. I am not able to print the drawing (make pdf), where the corner marks are just in the corner of the paper with no margin from each side in the QCAD. If you are please give me a hint how to do that.
ORM Model (1).pdf
(183.04 KiB) Downloaded 419 times
Nástavby ORM.dwg
(638.18 KiB) Downloaded 428 times
