[solved] Dimensioning Issue
bennett13
Post by bennett13 » Sun Mar 01, 2020 7:09 pm
It appears that a recent Windows update has caused QCAD to dimension 4 times the actual dimension. I am using QCAD 3.23.0, Windows Version 1903 (OS Build 18362.657). I only noticed the problem about a week ago, so it must be a recent update. Will there be a fix for this?
Re: Dimensioning Issue
Post by Husky » Sun Mar 01, 2020 7:54 pm
Please don't post the same question in different categories. We will recognize and respond to a question already at the first post ... :wink:
viewtopic.php?f=8&t=7015
