Hi, i'm building my cnc plasma, and going the Linux CNC route as i have the MESA ethernet boards.
so QCAD CAM can replace Sheetcam with an all-in-one solution ? CAD + CAM ?
i was planing on Librecad or inkscape for CAD and Sheetcam as CAM
QCAD CAM
Re: QCAD CAM
That depends largely on your exact requirements.
Please refer to our QCAD/CAM tutorials to get an idea of what is possible with QCAD/CAM at this point:
QCAD/CAM Introduction:
https://qcad.org/en/tutorial-qcad-cam
QCAD/CAM Nesting:
https://qcad.org/en/tutorial-nesting
And of course, you can download a free trial version from:
https://qcad.org/en/download#QCADCAM
QCAD/CAM Nesting:
Re: QCAD CAM
Well, tnx for the answer, as for my "exact requirements" i'm looking for a simple easy to use 2D CAD and a simple CAM like SHEETCAM
And i stumbled on QCAD + CAM
I'm a newbie on CAM stuff so i'm getting easyly confused, Any feed back from LinuxCNC using QCAD CAM for plasma cutting ?
Re: QCAD CAM
Hi Jay,
What would be your main requirements - just profile cutting, drilling, or would you need other options like Vcarve, engraving etc?
What would be your usual medium, wood, plastics or metals?
Many thanks
Clive
Many thanks
Clive
Re: QCAD CAM
Hi, it's for a plasma CNC, so only 2D cutting shapes
