What is the difference between free QCAD and Pro QCAD?
Zebulon
Post by Zebulon » Thu Sep 13, 2018 12:08 am
What are the differences between the free and pay versions of QCAD?
For example:
Can drawings be saved? If so in what format?
Are there feature limitations?
What advantages does the pay version have over the free version?
Re: What is the difference between free QCAD and Pro QCAD?
Post by Husky » Thu Sep 13, 2018 2:49 am
Yes.
dxf (R15), pdf, Bitmap formats.
Yes. What is included in each version can be found here:
https://qcad.org/en/documentation/features
For me? A lot!!! For you? I don't know - that is something what you have to figure out by yourself. Maybe you need the Pro feature, maybe not. The best way to figure that out is to get the Trial / Community Edition and work with it. :wink:
Clive
Moderator / Drawing Help
Post by Clive » Thu Sep 13, 2018 9:41 pm
Zebulon,
For me personally this is a 'no brainer' - for the low cost investment for the pro version, the return you get back is absolutely superb, whether you intend to use QCAD for private work or indeed commercial work!
