[solved] Problems with blocks
Marco_Bg
Post by Marco_Bg » Tue Jul 07, 2020 10:14 am
I'm trying QCad 3.24.3-64 but I have some problems to select blocks.
When I'm trying to edit an old block I cannot select the objects inside. If I draw a line in the old block it can be select.
Same in the main draw: some blocks is possible to select some other no.
I did some screenshots. Could you help me to understand what's wrong?
Thansk
Marco
Select is working and blocks are selected
Select 2 blocks on main draw
Only new lines are selected
Trying to select the 2 blocks with some new lines
Trying to select 2 blocks in main draw but nothing happen
Trying to select
Draw new lines in old block
Trying to select old block but nothing happen
Old block
Re: Problems with blocks
Post by Husky » Tue Jul 07, 2020 6:02 pm
... I did some screenshots. Could you help me to understand what's wrong?
thanks for the screenshots but in this case we need to see the dxf to see what is going on. Please attach the dxf to this topic for further investigation. Thanks.
Marco_Bg
Re: Problems with blocks [Solved]
Post by Marco_Bg » Thu Jul 09, 2020 6:24 am
Problem solved: I didn't notice that I blocked a level by mistake.
Thanks for fast reply anyway!
Marco
