Here are the lines I added:
in [LayerParameter]
LayerParameter fixed $T Tool_Change? Yes No
LayerParameter free $t 1 2 3 4 5 6 7 8
in
OrderToolChange
{<NewLine>t$t m6
<NewLine>g43 h$t}
OrderLayerStart
{<if:$l=Yes><UpdateLayer><NewLine><NewLine>(Layer: $_)
<if:$T=Yes><OrderToolChange></if>
</if>
My problem seems to be that once the <if:> statement runs, the variable is stuck on the value it had when first checked. All subsequent layers are stuck with that value. Other layer parameters that I have added seem to change by layer as long as I don't use them in an <if:>.
Any ideas on what I am missing?
Thanks,
Carl Helquist
using camexpert-2.0.4.8-1-prof.linux90.x86 on Ubuntu 8.04
