Change plunging axis/axis direction
Use this forum to ask questions about how to do things in CAM Expert.
Stachi
Post by Stachi » Fri Mar 12, 2010 4:23 pm
I'm using QCAD Pro (bought...) and tried the CAM Expert. Not a bad piece of software. But I've got one big problem:
I need the axis that plunges in to the material to be Y and not Z. And the direction (+/-) of the X-Axis needs to be mirrored.
How do I achieve this?
Marc
Post by andrew » Sun Mar 14, 2010 6:48 pm
You will have to adjust the CAM configuration file to achieve that. Start by looking at the file machines/gcode.cxm.
Replacing Y with Z and vice versa might do the trick. As for mirroring the X axis, it might be the easiest to mirror your drawing before exporting to CAM.
Return to “CAM Expert 'How Do I' Questions”
