Setting up cam expert for my machine
Use this forum to ask questions about how to do things in CAM Expert.
amada laser
Post by amada laser » Thu Dec 03, 2009 10:44 pm
Hi all , I have an Amada laser 667mkII with OM Fanuc controller .
I have attached a small snippet a typical g code , it is a very different animal to the code that I am getting out of cam expert .
Q . is there a way to configure the code that will be generated with cam expert ?
I am keen to start using my mac for the task rather than my Windows PC.
G00 X546.535 Y620.459
M98 P100
F3500.
G03 X544.535 Y618.459 I0 J-2.
G01 X544.535 Y617.459
X544.535 Y581.79
G03 X545.857 Y580.468 I1.322 J0
G01 X617.195 Y580.468
G03 X618.517 Y581.79 I0 J1.322
G01 X618.517 Y653.128
G03 X617.195 Y654.45 I-1.322 J0
G01 X545.857 Y654.45
G03 X544.535 Y653.128 I0 J-1.322
M61
Thanks Rick
Post by andrew » Fri Dec 04, 2009 9:03 am
Yes, you will have to adjust the file machines/gcode.cxm or make a copy of it.
See also reference manual:
http://www.ribbonsoft.com/camexpert/man ... ter05.html
DanielWenger
QCAM Expert machine def. files and location
Post by DanielWenger » Wed Mar 17, 2010 2:02 am
I recently purchased QCAM Expert and attempting to configure a machine file. No machine folder found. After creating one no way to reference it via QCAM. Help please.
stan.distortion
dxf to motion control
Post by stan.distortion » Sat Apr 17, 2010 12:27 am
Searched for 'motion control' and got this thread, will start new thread if need be, cheers.
Working on cnc, g-code is PITA, want to go straight from dxf to motion. Any advice?
thanks, stan
stan.distortion
Post by stan.distortion » Sat Apr 17, 2010 1:05 am
looking at dxflib at the mo
Return to “CAM Expert 'How Do I' Questions”
