QCAD 3.4.4 features a new dockable widget to select entities based on entity type and / or entity attributes.
This makes it easy to select all texts with a given text height or all lines longer than a given length, all entities with a given color, all ellipse entities, etc.
The widget can be shown through menu View > Selection Filter or by clicking the appropriate button in the tool bar at the right.
A bug in connection with custom text position of dimensions has been fixed.
A complete change log is available at:
http://www.qcad.org/en/qcad-documentati ... -changelog
Update instructions for QCAD Pro users:
http://www.qcad.org/en/customer-area
QCAD 3.4.4
QCAD 3.4.4
- select_text_height.png (24.77 KiB) Viewed 21521 times
- select_text_contains.png (24.01 KiB) Viewed 21521 times
- select_circle_area.png (24.46 KiB) Viewed 21521 times
