QCAD 3.4.1
Announcements of new QCAD Versions, Updates, new Documentation, ... Please refer also to the RibbonSoft web site.
QCAD 3.4.1
Post by andrew » Fri Oct 25, 2013 9:39 am
QCAD 3.4.1 is a bug fix release which fixes a potential crash under Windows with zero length lines and coordinate entry over the command line. This is also the first version to support Mac OS X Mavericks. Further, the file size of exported PDF files has been reduced significantly in some cases.
A complete change log is available at:
http://www.qcad.org/en/qcad-documentati ... -changelog
Update instructions for QCAD Pro users:
http://www.qcad.org/en/customer-area
Return to “Announcements”
