QCAD 3 RC5
Announcements of new QCAD Versions, Updates, new Documentation, ... Please refer also to the RibbonSoft web site.
QCAD 3 RC5
Post by andrew » Fri Apr 06, 2012 2:44 pm
This release fixes a few bugs and greatly improves stability.
ECMAScript Debugger
Previous RC releases had the ECMAScript debugger enabled by default. This turned out to lead to unpredictable crashes in various situations. QCAD 3 RC5 has the ECMAScript debugger disabled by default. If you need the script debugger, you can enable it by running QCAD with the -enable-script-debugger command line switch.
Return to “Announcements”
