SVG import function - maintaining line data.
This forum is a place where people can cast their vote for feature requests to be implemented from a selection of the top favorites submitted to the 'Bug tracker':
http://www.ribbonsoft.com/bugtracker/.
davecoventry
Post by davecoventry » Thu Jan 20, 2022 9:09 pm
If I export a 2D render of a FreeCAD model, I can specify that hidden lines can be presented in a specific colour so that they may be passed to a HIDDEN layer which I can specify the line type as dotted (HIDDEN) and the line colour as grey.
The Import SVG function in QCAD is a great facility, but it does not preserve this information in the imported file.
It would be great if this could be addressed.
Many thanks,
Dave
davecoventry
Re: SVG import function - maintaining line data.
Post by davecoventry » Wed Feb 02, 2022 5:12 am
If anybody else is looking for the same feature, it does already exist.
If one imports an SVG file which defines the line colour by using the xml description stroke="#ff00ff", for example, this is ignored as I have found previously.
However, if one uses the xml description style="stroke:#ff00ff", then the colour information is maintained and the line is rendered as magenta.
In linux, running the following command will set up the svg file for you:
sed -i 's/stroke=\"#ff00ff\"/style=\"stroke:#ff00ff\"/g' FreeCAD.svg
Post by CVH » Fri Feb 04, 2022 8:42 am
Nice catch.
Remark that the technology of dxf and svg is quite different.
One shouldn't expect a one-on-one conversion.
"Ignored" is a big word, properties are also inherited.
http://www.w3.org/TR/SVG/painting.html#StrokeProperty
Here stroke="#ff00ff" is a property.
From CAD point of view it inherits the Layer Properties.
style="stroke:#ff00ff" is an inline style.
From CAD point of view that is a specific property.
Return to “QCAD Voting Corner”
