Revision Cloud Tool
This forum is a place where people can cast their vote for feature requests to be implemented from a selection of the top favorites submitted to the 'Bug tracker':
http://www.ribbonsoft.com/bugtracker/.
sguttag
Revision Cloud Tool
Post by sguttag » Sun Mar 10, 2019 8:38 pm
If you've had the need to use a revision cloud, adding this tool would be key.
If you agree, please vote:
https://www.ribbonsoft.com/bugtracker/i ... &closedto=
Re: Revision Cloud Tool
Post by CVH » Fri Oct 18, 2019 4:01 am
Looked up Revision Cloud.
https://www.constructionknowledge.net/blog/?p=3742
You can imagine I am coding FlexPainter clouds.
These will not self-intersect...
Correction: I see, can't be avoided totally on any base
Anyone a good source for 'billows'?
http://app-help.vectorworks.net/2018/en ... Clouds.htm
QCADpro 3.24.3.0 / win7pro 32 bit / 4GB / 1e generation i7 2.6Ghz / HDD GeForce GT 520
Return to “QCAD Voting Corner”
