Default Template Folder
Posted: Wed Jun 15, 2016 12:57 pm
by caigner
It would be great if the Default Template Folder would be used as default for new drawings.
People, let's vote on this bug report from 2013 to get it fixed.
https://www.ribbonsoft.com/bugtracker/i ... ask_id=840
Christian
Re: Default Template Folder
Posted: Wed Jun 15, 2016 1:10 pm
What is the "Default Template Folder"? Where do you configure this setting? I cannot find such a setting anywhere in application preferences. Thanks.
Posted: Wed Jun 15, 2016 1:12 pm
I've changed this bug report into a feature request, since IMHO there is no such preference, so it can't possibly be broken
Posted: Wed Jun 15, 2016 1:21 pm
by caigner
It is under Load/Save Templates options menu. The directory entered there is not used as default template folder, as probably many of us think it should.
Posted: Wed Jun 15, 2016 1:23 pm
I've implemented this in the sense that the last used folder is remembered.
Posted: Wed Jun 15, 2016 1:25 pm
by caigner
There is a Default Template Directory button but if I select a directory it is not remembered.
Posted: Wed Jun 15, 2016 1:26 pm
caigner wrote:It is under Load/Save Templates options menu. The directory entered there is not used as default template folder, as probably many of us think it should.
That's actually a list of
additional directories which are available to choose from in the File > New from Template dialog. The default template directory is QCAD installation/libraries/templates, respectively the last used folder starting with the next release. I hope this solves the issue, please let me know if not.
Posted: Wed Jun 15, 2016 1:27 pm
caigner wrote:There is a Default Template Directory button but if I select a directory it is not remembered.
That button
switches to the default templates directory which is QCAD installation/libraries/templates. This should not be changed as users tend to get lost easily in their file system
Posted: Wed Jun 15, 2016 1:40 pm
by caigner
This is my template directory. When opening a new drawing I can select it:
- qcad_default_template_directory1.png (17.46 KiB) Viewed 29874 times
But when I open the New from Template dialog again, it is back to the default:
Posted: Wed Jun 15, 2016 1:48 pm
Again, remembering the last used folder has been implemented for the next release. Please let me know if there are any other issues. Thanks.
