Default Template Folder
This forum is a place where people can cast their vote for feature requests to be implemented from a selection of the top favorites submitted to the 'Bug tracker':
http://www.ribbonsoft.com/bugtracker/.
caigner
Post by caigner » Wed Jun 15, 2016 12:57 pm
It would be great if the Default Template Folder would be used as default for new drawings.
People, let's vote on this bug report from 2013 to get it fixed. :-)
https://www.ribbonsoft.com/bugtracker/i ... ask_id=840
Christian
QCAD Pro on Gentoo Linux
Re: Default Template Folder
Post by andrew » Wed Jun 15, 2016 1:10 pm
What is the "Default Template Folder"? Where do you configure this setting? I cannot find such a setting anywhere in application preferences. Thanks.
Post by andrew » Wed Jun 15, 2016 1:12 pm
I've changed this bug report into a feature request, since IMHO there is no such preference, so it can't possibly be broken :wink:
caigner
Post by caigner » Wed Jun 15, 2016 1:21 pm
It is under Load/Save Templates options menu. The directory entered there is not used as default template folder, as probably many of us think it should.
Post by andrew » Wed Jun 15, 2016 1:23 pm
I've implemented this in the sense that the last used folder is remembered.
caigner
Post by caigner » Wed Jun 15, 2016 1:25 pm
There is a Default Template Directory button but if I select a directory it is not remembered.
Post by andrew » Wed Jun 15, 2016 1:26 pm
caigner wrote:It is under Load/Save Templates options menu. The directory entered there is not used as default template folder, as probably many of us think it should.
That's actually a list of additional directories which are available to choose from in the File > New from Template dialog. The default template directory is QCAD installation/libraries/templates, respectively the last used folder starting with the next release. I hope this solves the issue, please let me know if not.
Post by andrew » Wed Jun 15, 2016 1:27 pm
caigner wrote:There is a Default Template Directory button but if I select a directory it is not remembered.
That button switches to the default templates directory which is QCAD installation/libraries/templates. This should not be changed as users tend to get lost easily in their file system :wink:
caigner
Post by caigner » Wed Jun 15, 2016 1:40 pm
This is my template directory. When opening a new drawing I can select it:
But when I open the New from Template dialog again, it is back to the default:
Post by andrew » Wed Jun 15, 2016 1:48 pm
Again, remembering the last used folder has been implemented for the next release. Please let me know if there are any other issues. Thanks.
Return to “QCAD Voting Corner”
