[solved] Add Block Attributes
oldStrogg
Post by oldStrogg » Sat Aug 28, 2021 2:29 pm
please take a look on my simple script, and tell/direct me what do I miss.
When I place block manualy, all ok. All Block Attributs on place.
But script not add Block Attributes ("Dependent Entities"). Only Block itself.
How add Block Childes and change there values before op.addObject(blockEntity); ?
di.setCurrentLayer("myLayer");
var op = new RAddObjectsOperation();
var blockId = document.getBlockId("blockName");
var position = new RVector(x,y);
var scale = new RVector(1,1);
var angle = RMath.deg2rad(0);
var columnCount = 1;
var rowCount = 1;
var columnSpacing = 0;
var rowSpacing = 0;
var blockEntity = new RBlockReferenceEntity(document, new RBlockReferenceData (
    blockId,
    position,
    scale,
    angle,
    columnCount,
    rowCount,
    columnSpacing,
    rowSpacing
op.addObject(blockEntity, false)
di.applyOperation(op);
Thankyou.
Re: Add Block Attributes
Post by CVH » Sat Aug 28, 2021 6:08 pm
hi,
we see you creating a new RBlockReferenceData and casting a new RBlockReferenceEntity to the document.
But your script doesn't handle any attribute entities in the block.
Have a look at AddBlock.js https://github.com/qcad/qcad/blob/maste ... ddBlock.js
And further: Block.js & BlockDialog.js ...
Post by CVH » Sun Aug 29, 2021 6:53 am
In this common case one uses InsertBlock.js https://github.com/qcad/qcad/blob/maste ... rtBlock.js
There the .getOperation function handles attributes entities in the block.
oldStrogg
Post by oldStrogg » Wed Sep 01, 2021 4:30 pm
Thank you very much, CVH.
Its solve my problem.
For beginners like me, it is hard to find right piece of code in such huge js soft.
