Batch export to PDF from GUI
Hi there! I wrote a small script. Batch export to multi-page PDF from GUI. It exports the visible (unfrozen) layout blocks in the same order as in the block list widget. I hope it will be useful to someone. I am a beginner in Javascript. The script probably contains bugs. I only tested in win 10.
- Batch2Pdf.zip
- (33.84 KiB) Downloaded 505 times
Re: Batch export to PDF from GUI
Thank you for your contribution!
Can you please clarify if this can be included in the next QCAD release? If so, please indicate under what name we can list you under Help > About > Credits (this can be a real name or a nick name such as "dmitpon". We'd put this under Misc > Import/Export.
Hello, Andrew! I agree to include this script in the next QCAD release. My real name is Dmitry Ponomarev.
Excellent, thanks!
I've added this to the repository at:
https://github.com/qcad/qcad/tree/maste ... /Batch2Pdf
Ok, I'm glad my script was useful.
