Setting layers of texts and dimensions
dfriasb
Senior Member
Post by dfriasb » Sun Mar 14, 2021 9:23 pm
Hello all,
I'm writing a script for changing layers of all texts and dimensions simultaneously:
var document = this.getDocument();
var entitiesIds = document.queryAllEntities(false, false);
for (var i=0; i<entitiesIds.length; i++) {
    entityId = entitiesIds[i];
    entity = document.queryEntity(entityId);
    if (isDimensionEntity(entity)) {
        entity.setLayerName("dim.");
        entity.update();
        op.addObject(entity)
    else if (isTextEntity(entity)) {
        entity.setLayerName("ret.");
        entity.update();
    }   // looping ends
di.applyOperation(op);
Texts should result to be in layer called "ret." and dimensions in layer "dim.". But it's not working like this. It seems it is changing all entities to layer "dim". I guess something is not working as I want in the loop.
Any help will be very welcomed. Best regards!
David
Re: Setting layers of texts and dimensions
Post by CVH » Mon Mar 15, 2021 5:48 am
The addObject signature is found here:
https://www.qcad.org/doc/qcad/latest/de ... 57f845ec3a
useCurrentAttributes defaults to true.
forceNew defaults to false.
Meaning you don't add new entities but you update them all with the current attributes.
The current active layer was 'dim.' when you ran the script :!:
I don't see any reason to mark them as dirty with entity.update();
As you apply the update yourself.
    var entity = document.queryEntity(entitiesIds[i]);
        op.addObject(entity, false)
}   // looping ends
Now, document.queryAllEntities(false, false); can be slow, returns all entities but doesn't query in Blocks.
https://www.qcad.org/doc/qcad/latest/de ... 3c488b7f9d
One can query all of a kind by:
document.queryAllEntities(false, false, RS.EntityDimension);
document.queryAllEntities(false, false, RS.EntityText);
Or use a list of types, more here:
https://www.qcad.org/doc/qcad/latest/de ... 2885832771
Also remark that a Dim or Text General Property 'byLayer' would mean 'by new layer'. :wink:
Declaring your variables is best practice (entityId, entity). :wink:
Dacicusan
Post by Dacicusan » Mon Jan 17, 2022 12:52 pm
How can I use this script?
Post by CVH » Mon Jan 17, 2022 5:32 pm
Dacicusan,
A finished script was not shared.
Basically this was Q&A about scripting it.
