I had the same question a year or two ago.
Came up with a script to document all the selected basic entities.
I am not happy with it but I use it as it is.
It uses number2string what uses sprintf.js what you have to include.
In general this is fine but not always.
The main structure looks like this. (Including my own comments and other junk)
* \ingroup ecma_misc_examples_ioexamples
* \class DocBasicEntities
* This action documents all selected basic entities as plain text into the
* command line history and/or a CSV file.
* The goal is to export full reproducible data to CSV for basic entities.
* The output to the command line history is kept less verbose.
* For some types the exported data is merely informational.
* Still in development. Lookup #ToDo#, # #, #Busy#.
* Translation is mostly not prepared. (#ToDo# Howto prepare for translation)
function DocBasicEntities(guiAction) {
IOExamples.call(this, guiAction);
DocBasicEntities.prototype = new IOExamples();
DocBasicEntities.prototype.beginEvent = function() {
IOExamples.prototype.beginEvent.call(this);
debugger; // To pause and open the debugger window
Usefull info | Generals
https:// www.qcad.org/rsforum/viewtopic.php?f=30&t=6125
var layerId = entity.getLayerId();
var layer = document.queryLayer(layerId);
var layerLineweight = layer.getLineweight();
(#ToDo# ByBlock & ByLayer >> + block/layer props | list of mentioned layers with props)
https://qcad.org/rsforum/viewtopic.php?f=30&t=5558#p20742
var testp = entity.getExploded()
structure is similar => howto did they export
Every spline can be represented by a poly, polys have an orientation. #ToDo# Spline orientation
#ToDo# Local & Global 3D check
entityTypeToString(type, plural)
* Converts the given entity type enum to a human readable,
* translated string.
angleToString(num, decimals)
# # numberToString(argument,digits) parses scientific notation for near zero values
# # .arg() can't be boolean
# # Missing critical error sound
# # isBlockReferenceEntity(obj): Is a blockref a basic entity?
# # Polyline can not include full arc segment: Bulge = tan(sweep/4) -> tan(90) = infinite
Null-arcs can have a near full sweep
# # Polyline Large +/-GlobalZ with none zero GlobalWidth act funny on Bulges. Filled Bugreport
# # Image type have attributes for Brightness and Contrast. Not used in Qcad.
entity.getBrightness entity.getContrast
var di = this.getDocumentInterface(); // DO NOT understand setting of di
// Variable was originally not used in ExDumpPolyline.js
var ids = document.querySelectedEntities(); // Qlist with selected
var idCount = ids.length; // Number of selected is Qlist length
var dmpCom = idCount <= 5; // Flag, dump to command history when selection <=5 or no (open) file
var dmpDecimals = 4; // Decimal places on command history
var csvExp = false; // Flag, CSV export when selection >5 and open file
var csvDecimals = 10; // Decimal places on CSV export
var idn = idCount; // Number to process
var idp = 0; // Counter processed
var firtsOfType = true; // Flag, use type header if true
var lstSep = (RSettings.getStringValue("Input/DecimalPoint", ".") == ".") ? "," : ";";
// List separator string 0.00->, 0,00->;
var i , id , entity; // Common loop variables
var posRv , startRv , endRv , aux1Rv; // Intermediate Rvectors storage
var objCol , objLineW , objLineT , objLineTS; // Intermediate general attributes storage
var nominator = "" , msg = "" , reMark =""; // Message strings
EAction.handleUserCommand("IOExamples: Document Basic Entities"); // Push command to history
if (idCount == 0) { // Terminate without entities selected
EAction.handleUserWarning("No entities selected!"); // Push warning to history
this.terminate();
return;
var fileName = this.getFileName(); // .getFileName as in BlockListExport.js
if (isNull(fileName)) { // Without a filename >
dmpCom = true; // Force dump on command history
} else { // With a filename >
var file = new QFile(fileName);
var flags = new QIODevice.OpenMode(QIODevice.WriteOnly | QIODevice.Text);
if (!file.open(flags)) { // Without open file >
EAction.handleUserWarning("No file opened!");
} else { // With open file >
csvExp = true; // CSV export
if (dmpCom) EAction.handleUserInfo("Basic Entities Dump:");
if (csvExp) {
var ts = new QTextStream(file);
ts.writeString("Basic Entities Dump:");
ts.writeString("\nSelected entities: "+ idCount);
ts.writeString("\n+++++ ++++++++ +++++");
// Type: Point entity types #Done# Reproducible
// Nominator | Layer | Color | LineWeight | LineType | LineTypeScale |
// Position x | y | z |
for (i=idn-1; i>=0; i--) { // Cycle through all selected
// Backwards what is conveniently for splicing out Qlist items
id = ids[i]; // Pick Qlist entry
entity = document.queryEntity(id); // Pick entity
if (isPointEntity(entity)) { // Process entity if it is of point type
if (firtsOfType) { // Type header
if (dmpCom) EAction.handleUserMessage("Point dump:");
if (csvExp) ts.writeString("\n\nPoint dump:\nNominator; Layer; Color; LineWeight; LineType; LineTypeScale; Position x; y; z;");
firtsOfType = false;
nominator = "Point";
objCol = entity.getColor(); // Color name from Rcolor class of core module. Can be ByLayer, ByColor
objLineW = entity.getLineweight(); //Lineweight name from RLineweight class . Can be ByLayer, ByColor
objLineT = entity.getLinetypeId(); // Each document has its own linetypes. Can be ByLayer, ByColor
objLineTS = entity.getLinetypeScale();
posRv = entity.getPosition();
if (dmpCom) { // Less verbose report on command history
EAction.handleUserMessage(mkFormatS(4, lstSep) // ... Make argument list string with 4 entries
.arg(nominator)
.arg(numberToString(posRv.x, dmpDecimals))
.arg(numberToString(posRv.y, dmpDecimals))
.arg(numberToString(posRv.z, dmpDecimals)));
if (csvExp) { // Full reproducible data to CSV
ts.writeString("\n" + mkFormatS(9, lstSep) // ... Make argument list string with 9 entries
.arg(nominator)
.arg(entity.getLayerName())
.arg(objCol.getName())
.arg(RLineweight.getName(objLineW))
.arg(document.getLinetypeLabel(objLineT)) // getLinetypeName is less conform
.arg(numberToString(objLineTS, csvDecimals))
.arg(numberToString(posRv.x, csvDecimals))
.arg(numberToString(posRv.y, csvDecimals))
.arg(numberToString(posRv.z, csvDecimals)));
idp++; // Increase processed counter
// Do not re-process this entity for other types
ids.splice(i,1); // Remove entity from Qlist
idn--; // Decrease number to process
// One could deselect the entity one by one at these points
// di.deselectEntity(id); // This needs var di to be set
firtsOfType = true;
// Type: LineBased entity types #Done# Reproducible
// Type: Arc
// Type: Circle ... Ellipse ... Spline ... Poly and on and on
// firtsOfType = true; // Not needed after last type
if (dmpCom) EAction.handleUserInfo("+++++ Dump END +++++");
if (csvExp) {
ts.writeString("\n\nEntities exported: " + idp + " of " + idCount);
ts.writeString("\n+++++ Dump END +++++");
file.close();
if (idp == 0) {
EAction.handleUserMessage("Nothing to export");
EAction.handleUserMessage("Export terminated: " + fileName);
} else {
EAction.handleUserMessage("Export complete: " + fileName);
// EAction.activateMainWindow();
this.terminate();
Sorry I can't give you all the types handling.
You will need this function too:
// Construction of formatting string
mkFormatS = function(partsCount, lstSep) {
var formatS = ""; // Formatting string
for (var k=0; k<partsCount; k++) {
formatS += "%" + (k+1) + lstSep;
return formatS;
And this is the module that does the filename handling.
It uses File.js what you have to include.
I am not happy with the persistent folder handling.
// CVH added: .getFileName as in BlockListExport.js
DocBasicEntities.prototype.getFileName = function() {
var drawingFileName = this.getDocument().getFileName();
var fi;
var fileName;
var initialPath = "";
if (drawingFileName.length === 0) {
var path = RSettings.getStringValue("DocBasicEntities/Path", QDir.homePath());
fi = new QFileInfo(path);
initialPath = fi.absoluteFilePath() + QDir.separator +
stripDirtyFlag(EAction.getMdiChild().windowTitle) + ".csv";
} else {
fi = new QFileInfo(drawingFileName);
initialPath = fi.path() + QDir.separator + fi.completeBaseName() + ".csv";
var appWin = EAction.getMainWindow();
var ret = File.getSaveFileName(appWin, qsTr("Document Basic Entities (CSV)"),
initialPath, [ qsTr("CSV") + " (*.csv)" ]);
if (isNull(ret)) {
return undefined;
fileName = ret[0];
if (fileName === "") {
return undefined;
RSettings.setValue("DocBasicEntities/Path", new QFileInfo(fileName).absolutePath());
return fileName;
CVH.
