Page 2 of 2
Re: script collection for layer config, multiprint, reconcile...
Posted: Wed Jul 10, 2019 7:27 am
by smf
Hi Olly.
Thank you for the detailled report. Unfortunately I have no idea what's wrong: directory structure looks perfect to me and QCad is the same version as mine (except Linux instead of MacOS). :(
I'll ask Andrew. :oops:
Regards - smf
Posted: Wed Jul 10, 2019 11:26 am
olly: What are you trying to do with the selection widget? Perhaps you can use the selection filter for now (View > Selection Filter).
See also:
https://qcad.org/doc/qcad/latest/refere ... tionFilter
Posted: Thu Jul 11, 2019 9:59 pm
by olly
Hi Andrew,
yes I use it every day
From complete CAD-Drawings from my costumers I extract elements for milling, drilling etc. So i have to delete all entities are not needed!
Selectionfilter is perfect for specifying circles of the same size to mark them with a specified tolerance.
Select Widget has not the flexibility of Selectionfilter!
The Advantage is deleting quickly unnecessary Entities.
After selecting all elements the menu shows only existing Entities, so its easy to select for example all text und delete it.
And no need to search for Points if there are no Points in the drawing.
My wish would be to work with a Menu in Selectionfilter of that kind ;-)
Posted: Thu Jul 11, 2019 10:06 pm
by olly
Hi smf
the standalone widget worked perfect before the actual Qcad version the black window maybe results from dark mode ?
Posted: Fri Jul 12, 2019 6:01 am
by smf
Hi olly,
I never tested dark mode - but I doubt standard components would have that impact. Could you test dark mode switched off?
Regards - smf
Posted: Fri Jul 12, 2019 7:10 am
by olly
Hi smf
yes i testet it on os Version without dark mode
olly
Posted: Fri Jul 12, 2019 12:39 pm
I've added selection counters to the entity combo for the next release, so it can be used to determine how many entities of a given type are selected:
Screen Shot 2019-07-12 at 12.37.49.png (94.54 KiB) Viewed 6218 times
I hope that's helpful for your use case.
Posted: Fri Jul 12, 2019 10:11 pm
by olly
Hi Andrew,
this is the perfect solution
I will wait for the next version
Thank you
Posted: Mon Jul 15, 2019 10:36 am
A snapshot release (3.22.1.6) with this feature is now available.
Posted: Mon Jul 15, 2019 11:02 am
by olly
excellent exactly what I need ;-)
