Script attached: box joints
- Junior Member
I build a lot of funny things with plywood on my laser cutter. I used to spend a lot of time creating box joints (you know, the finger-slot-finger-slot thingies that are somewhat difficult to glue, but hold great thanks to the huge surface). Not any longer thanks to the QCAD script I wrote (isn't scriptable software great?).
This script adds a Box Joint icon in the Draw/Line menu and the tool box. The shortcut is L,J. The tool works with two clicks, one where you start the box joint, and the second one where it ends (just try it, you'll see). Box joints are the same forward and backward, and for the slots. So if you do select points with the same distance for both ends of a workpiece, the pieces will mesh just fine.
Just as a hint: when joining two sides at a 90 deg angle, just create the box joint from corner to corner. If you plan a top or bottom plate as well, the box joint should start and end at the corner plus the thickness of the top and bottom (I guess I have to make a video - it's hard to put into words).
The License is LGPL 3. Andrew, feel free to put the script on your page if you like it or make it part of QCAD. Although, an even better implementation probably would be an interactive block for the library?!
Enjoy,
- Matthias
[Edit from andrew: please note that this script might be outdated. The latest version is available in all newer QCAD installations under Misc > Draw]
Enjoy,
- Matthias
- boxjoint_v1.tgz
- archive starts at "scripts/.."
- (5.46 KiB) Downloaded 1356 times
Re: Script attached: box joints
Hi Matthias
Nice work
All you need to do now is write a script for creating dovetail joints
Nice work
Out of interest, what thickness are you running through the cutter?matthiaswm wrote:I build a lot of funny things with plywood on my laser cutter.
Tell me about it , after years of furniture making you start to see all manner of joints before your eyesmatthiaswm wrote:I used to spend a lot of time creating box joints
Looking forward to itmatthiaswm wrote:(I guess I have to make a video - it's hard to put into words).
- Junior Member
3mm birch, 4mm HDF, and 2-12mm Plexi are my standard materials. Box joints in 12mm Plexi look very neat!clive wrote:Out of interest, what thickness are you running through the cutter?matthiaswm wrote:I build a lot of funny things with plywood on my laser cutter.
Well, no big deal really, but the laser cutter won't cut it (no pun intended). I am considering a puzzle plugin though.clive wrote:All you need to do now is write a script for creating dovetail joints
Yes I am using the same range of materials with the addition of paper and card stock and real wood veneers.matthiaswm wrote:3mm birch, 4mm HDF, and 2-12mm Plexi are my standard materials. Box joints in 12mm Plexi look very neat!
Just make them 2D only and not mitred/bevelledmatthiaswm wrote:but the laser cutter won't cut it
Yes please ..... I'm also curios to see that!!!matthiaswm wrote:(I guess I have to make a video - it's hard to put into words)
- Junior Member
Allright. Here is the video. Not sure if it explains it better, but you can see me struggling to talk and make a drawer at the same time:
http://youtu.be/MAqGHF9IvU0
- Matthias
- Matthias
I can see how this is a huge time saver. This is an excellent example for using scripts. It also makes me feel that QCAD 3 scripting might be on the right track Thanks for sharing!
I absolutely agree: Nice script!!!andrew wrote:I can see how this is a huge time saver.
Yep - that is also something what I'm looking for ... and I'm sure - there are many more like us out there!!!clive wrote:All you need to do now is write a script for creating dovetail joints
Right - but there are more tools out there without a laser ....matthiaswm wrote:Well, no big deal really, but the laser cutter won't cut it.
Thanks matthiaswm for sharing that - and please reconsider a "Dovetail joint script" ....
Hi Matthias
Your 'Box joint' script is an absolute blessing for me, I am finding it invaluable for medieval castle design, for typical curtain walls etc. it is just perfect .
Here is an example of a 'typical' castle curtain wall.
- Junior Member
The source code is available, so you can easily add the arrow holes .
Matthias, if I could - I would, I'm afraid I don't know any coding at all but I would be willing to learn how to do some basic scripting in QCAD, all I need is some tuition. I have tried to figure out how to do some from the examples given on the main website - but for me I need a beginners guide to scripting in QCAD.
I am more that willing to learn and I just hope that Andrew or anyone willing to, could write up a basic introduction for starting to script in QCAD. I know I don't speak only for myself when I say that I would love to try and contribute to QCAD in this way.
@Andrew, what do you think - any chance of this?
Hi Guys
Matthias I tried your box joint script this morning and I'm quite impressed by the design assistance it brings...Clive, I support your comment on script learning, I tried to look into he documentation but gave up. A step by step progression is required when one is an absolute beginner!
clive wrote:@Andrew, what do you think - any chance of this?
It's always a tough call how much time to invest on documentation and how much on bug fixing and implementing new features. I generally enjoy writing technical documentation, but I also know how much work it is.
I am planning to provide more documentation and tutorials for script development one way or anther.
Programming basics will always be a prerequisite. I personally believe that programming is something one can only learn by experimenting, reading code, modifying code, writing code. There is no school or book that will teach you how to program. Trying to extend QCAD with your own tools or add-ons is actually a great way of learning how to program You can't really screw up anything, you don't need a compiler or IDE, QCAD and a plain text editor is everything that is needed. ECMAScript (JavaScript) is also one of the most popular languages used today which means there are plenty of resources available online for generic JavaScript problems. E.g. google for "javascript convert string to number" or "javascript append to array", etc.
If I would know nothing about QCAD script development, I would first have a look at the script source code of a simple, existing script (e.g. the tool that draws points in scripts/Draw/Point/Point1P/Point1P.js). Then I would try to change its behavior, for example draw two points beside each other instead of one. Then I would try to copy that new script into a new, independent script and rename it. Step by step taking one tiny step at a time, after each step checking if it is working as expected.
Thank you Andrew for your words of encouragement here, getting the balance on where to spend the time in any commercial business is essential and I fully understand.
I look forward to any documentation/tutorials that you may be able to offer, for me I would think that a 'work - along' type of workbook would be good with examples and exercises that people can use, this type of workbook is the best and I would think that something like this could easily be added to accompany the existing 'QCAD book' as another book that people can purchase.
Yes I agree that actually doing and experimenting is the best way to learn anything and I guess that part is up to me/others to get 'stuck in' and give things a go and of course we have the 'Developers' forum to ask questions in.
Thanks again.
Thanks again.
Matthias: I've included this script in the latest QCAD release (3.1.5) under menu Misc - Drawing.
On github, it is checked in under:
https://github.com/qcad/qcad/tree/maste ... neBoxjoint
Thanks for this contribution!
