model railroad track planning
Post by Husky » Sat Jan 21, 2017 4:34 am
smf wrote:I'm still playing around with QCad and QCTrack, but it "just works", so there was no need for an update.
Hi smf - glad to hear that! I updated your library file list. :wink:
smf
Post by smf » Mon Feb 11, 2019 8:40 pm
Hi there,
somewhere before QCad 3.21 there were some changes that I completely missed. Sorry! :oops: So the version 101 of QCTrack does not work with the current version of QCad. After massive help of Andrew (thank you!) I will upload an updated QCTrack version for the next official QCad version as soon as possible.
Regards - smf
smf
Post by smf » Sat Apr 27, 2019 2:36 pm
Hi there,
sorry for the long offline-time (read: family-time). Attached is the new QCTrack version 102 which is tested with QCad 3.22.0 and seems :wink: to work. If you have any problems, please report them here.
@Husky: if you're still here, please update the "newest version" thread. Thank you! :D
@Andrew: thank you for your help and special QCad-extension! :) :) :)
Best regards
smf
QCTrack_V102_QCad3220.zip
(76.82 KiB) Downloaded 165 times
Post by Husky » Sun Apr 28, 2019 9:40 am
Done! :wink:
