Vector += vector
tukuyomi
Vector += vector
Post by tukuyomi » Thu Aug 25, 2016 1:11 pm
Hello ! I have a little question :
var v = new RVector(1,2) , v1 = new RVector(4,8);
    qDebug("1>"+v)
    qDebug("2>"+v1)
v.operator+=(v1);
    qDebug("3>"+v)
What to expect, doing this? Here is what I get :
Debug:    1>RVector(1, 2, 0, true)
Debug:    2>RVector(4, 8, 0, true)
Debug:    3>RVector(1, 2, 0, true)
Is it possible to have
Debug:    3>RVector(5, 10, 0, true)
(add 2 vectors) ?
Thanks for your answers !
Re: Vector += vector
Post by andrew » Thu Aug 25, 2016 1:16 pm
ECMAScript does not support overloading of operators, so you'll have to use the workaround functions for operators:
var v3 = v1.operator_add(v2);
Similarly, there are operator_subtract, operator_multiply, operator_divide and getNegated(v) for -v.
tukuyomi
Post by tukuyomi » Thu Aug 25, 2016 1:29 pm
Thanks andrew :D Will try this asap :D Thank you !
