Vector compare ?
srl
Vector compare ?
Post by srl » Fri May 20, 2016 12:43 am
Hi Andrew I can't get this vector compare to return true.
Screenshot from 2016-05-20 09-01-18.png (291.8 KiB) Viewed 6678 times
srl
Re: Vector compare ?
Post by andrew » Fri May 20, 2016 9:05 am
To compare two vectors, use:
vector1.equalsFuzzy(vector2)
To compare two doubles (real or floating point numeric values):
RMath.fuzzyCompare(value1, value2)
The == operator should never be used when dealing with floating point values since floating point arithmetic is not always 100% accurate:
0.1+0.2==0.3
false
With vectors and other objects, == does not work even if two vector are exactly identical since == compares the objects for identity, not the values inside:
var a = new RVector(0,0);
var b = new RVector(0,0);
a==b
false
a==a
true
srl
Post by srl » Fri May 20, 2016 12:02 pm
Thanks Andrew.
As you can see I'm been on the LinuxCNC simulator. P2 makes the full arc circle work with offset.
Still more testing to be done.
srl
