Coordinates of the extreme points of the selected line?
pietro_72_
Location: http://creativitainformaticart.altervista.org
Post by pietro_72_ » Sun May 15, 2016 7:43 am
Salve
Vorrei ottenere in javascript le coordinate dei punti estremi di una retta selezionata, come si deve fare?
C'è anche un modo, tramite pulsante, di richiamare la modalit
C'è anche un modo, tramite un pulsante, di richiamare la modalità di selezione?
Translated by google
Hello
I would get in javascript coordinates of the extreme points of the selected line , as it should do?
There is also a way , via a button, to call the selection mode ?
Re: Coordinates of the extreme points of the selected line?
Post by andrew » Tue May 17, 2016 8:03 am
You can get the bounding box of an entity using entity.getBoundingBox().
Please refer to scripts/Misc/MiscDraw/DrawBoundingBox/DrawBoundingBox.js for a complete example which draws bounding boxes around selected entities.
pietro_72_
Post by pietro_72_ » Thu May 26, 2016 7:15 am
Bounding Box = Box (Vector ( 25 , 15 , 0 , true) - Vector ( 48 , 28 , 0 , true) )
Is there any method / property that returns the X and Y coordinates of the vectors contained in the BoundingBox ?
Post by andrew » Thu May 26, 2016 8:05 am
You have:
box.getCorner1()
box.getCorner2()
or:
box.getMinimum()
box.getMaximum()
All of these return RVector objects. You can then use the x and y properties for the x/y values:
var box = new RBox(new RVector(0,0), new RVector(100,50));
var c1 = box.getCorner1();
var c2 = box.getCorner2();
var x1 = c1.x;
var y1 = c1.y;
var x2 = c2.x;
var y2 = c2.y;
pietro_72_
Post by pietro_72_ » Fri May 27, 2016 7:09 am
thank you
pietro_72_
Post by pietro_72_ » Sat Jun 04, 2016 8:11 am
Risolto
Sono riuscito ad ottenere quello che volevo in questo modo:
Solved
I managed to get what I wanted in this way :
var ids = document.querySelectedEntities();
var i;
for (i=0; i<ids.length; i++) {
var id = ids;
var entity = document.queryEntity(id);
var x1 = entity.getEndPoints()[0].x;
var y1 = entity.getEndPoints()[0].y;
var x2 = entity.getEndPoints()[1].x;
var y2 = entity.getEndPoints()[1].y;
